I recently bought a Grundig G3 shortwave radio and put up a 14 ga., 50' insulated solid copper wire antenna. I used a smaller diameter multi strand copper feed wire in to my radio with an alligator clip to connect it to the radios whip antenna. What would be the best way to ground this set up and will a ground wire cut down on some of static/noise that I'm picking up? I'm new to SWL and would appreciate any advise.
Bob
Bob
