Grounding problem?
It may be a grounding problem. It really isn't the plastic knobs, but just having your hand that close to the radio. That's typically a sign of CMCs, which basically means the best 'cure' would be at the antenna where that sort of thing starts, a choke or whatever.
Usually, the 'cure' is inconvenient for whatever reason, but that's the way it goes...
