HELP NEEDED
chris_53
Aug 5, 2005
12
Hi all, im new to the world of cb radio and need a little help please, ive set up a rig at home and the antenna i am using is an 18ft 1/2 wave antenna recommended by local cb shop..What i need to know is....does height make a lot of difference, at present the top of the antenna is only about 24ft high, another thing i need to know is i have it mounted straight onto the wall of the house, would i be better mounting it onto a steel pole,..........i hope someone can help me with this questions please, ive checked my SWR and its below 2 but still seem to be having some probs getting other users more than about 5 miles from my home.
many thanks in advance.....CHRIS
The best height is 36ft or higher to the bottom of
antenna. (Where coax connector plugs in)...
If you can't get it up safely to that height, get it
up as far as you can.
Yes, use a steel mast on antenna. Your SWRS should
lower once you get it away from everything.
Also as stated by FL Native, Lowes sells 30ft push-
up telescopic mast.
Reactions: Groundhog KSS-2012
