Help Uniden Grant XL
PLL alignment for 208AA or 208AD = Uniden Grant XL & Grant LT with 11.3258 crystal
5. Adjust L59 by similar connection of (4) to obtain within 34.9865MHz +/-20Hz as will be indicated by frequency counter, then set Mode switch back to "AM".
6. Change moode switch to "AM" and adjust L23 to obtain within 34.985 +/-20Hz
7. Change Mode switch to LSB and adjust L22 to obtain within 34.9835MHz +/-20Hz as to be indicated by freq counter.
Above from cbtricks
Link to cbtricks http://www.cbtricks.com/radios/uniden/grant_lt/grant-lt_pll_adj.htm
Link to Depfom http://www.radiomods.co.nz/alignments/grantxlalignment.html
Bellow from Radiomods
Input of frequency counter to TP3 (between L19 and L47)
Ch. 19, USB Clarifier Midrange L59 Adjust for 34.985 MHz (FCC).
Ch. 19, USB Clarifier Midrange L23 Adjust for 34.9815MHz (FCC).
Ch. 19, USB Clarifier Midrange L22 Adjust for 34.9885MHz (FCC).
They have different alignment instructions which of the 2 is correct ??
Thank you for your help
Andy
Im having the exact same trouble with a grant xl i just recently aqquired and im gonna put allback to stock condition if i can
