Moleculo could you grund the ladder to the frame? Just use a good type coax? If you dont tow a car you could run small pipe coming off a reese hitch. Slide on a towing hitch to the conector and run the pipe from there.
What you're doing is turning the whole frame into your groundplane. On a motor home, it's a little too far from the antenna, but everything is a compromise in this situation. Also, the ladder will give it some counterpoise.
I would opt for the mirror mount, that way you could run a larger and better antenna, like a Wilson 2000 trucker. A 1' or 2' fiberglass antenna ain't gonna do squat for you.
