We have talked about this before but I was trying to compare data sheets for the TIP36C and the 2SB817. While everyone says the TIP36C is stronger / better and I am probably looking at this wrong in some respects the 2SB817 looks stronger. What is the main thing to look for?
Collector base voltage is better on the 2SB817.
Collector emitter voltage better on the 2SB817.
Max emitter base voltage better on the 2SB817.
Max collector current is the only thing that really seems better on the TIP36C. I May be looking at the wrong things so hopefully someone can explain what to look for.
Thanks.
Thanks.
