Help with skipshooter double barrel
meter is good for 200 watts skipshooter rated for 5000 watts I zeroed the meter for the frequency didn't have to change for power level. I was ablet to get the tram to 1.3 across the board fairly quickly tram says 1.3 is the best that antenna will do
Reactions: RT431
5 without the amp stinger fully down 4.5 with no amp stinger extended
I did receive a call from Skipshooter today they are sending me a new one with more adjustment.
the amp is ok.get antenna set rite n it will talk
Got the new antenna today swr was slightly better but still not good the whip was much shorter had 1.1 on 40 and 2.2 on 1. with stinger all the way down I trimmed about 1/8: off swr seemed to go up slightly across the band. It was getting dark so I gave up for the day.
Reactions: Rwb
  • @ Hambones amps:
