HELP!
alright i got good news. i have another cb that i set up in my room with a ghetto antenna. i can hear my cb in the truck from in my room. so why arent i getting out past the half mile or so that i tested it?
Are you testing this with the squelch wide open, or closed? Also, does this radio have an RF Gain knob? I think you need to tell us more about what kind of radio it is and how you installed it before we can be of much help....
Do you have an external power and swr meter? If not, get an inexpensive one. They're around $20. I think you have a problem with your installation or the coax. Hook up the meter after your radio with a jumper, and tell check the swr and power output of the radio. If the SWR is high (greater than 2:1), you have a problem with the antenna, coax, or mount. If you're not sure how to use an SWR meter, read this link: www.firestik.com/Tech_Docs/swr-intro.htm. Ignore the parts on that page about coax length, though.[/img]
