how often do you use the 10 meter channels on your export ?
  • Start date Start date
how often do you talk on 10 meters ?
  • most days
    Votes: 0 0.0%
  • every 4-7 days
    Votes: 0 0.0%
  • once or twice every few months or so
    Votes: 0 0.0%
  • very very rarely
    Votes: 0 0.0%
  • Total voters
    201
B
BOOTY MONSTER
Guest
i hardly ever hear anyone on 10 meters . i may go spin around a few bands on it every few weeks with pretty much empty results . im finding that in my application/use its pretty much a unused feature . ive seen a few post here and there by others saying more or less the same thing . i do make contacts on the regular cb 40 and ssb and i seem to have good ears .
i was wondering how frequently folks here communicate on 10 meters (and 12 meters for you 2950/70 owners) . i know some of yall use ham riggs and can go all over the place . when i menton day i dont mean every day of the week cause some folks may not talk every day , but every day that you turn on the radio to use it .
thanks for indulging my boredom and playing along :D
That's because we are in a low cycle. When the conditions begin to come back, you won't be able to stir 'em with a stick.
Every frequency available will be full. These "cycles" occur about every 11 years. Even the 10M FM repeaters will be hopping up and down.
Another thing is, (and a disadvantage of the "channelized" radios), sometimes hams will be talking on those frequencies that don't end in "5" like the CB-clones do. You may not be able to clarify the signals.
There's several groups of us that meet on 28.403 SSB, 28.610, and 28.450 locally. Ten meters gets plenty of use. The lower end of 10 Meters won't BE filled with voices since it is reserved for Morse and digital modes.
CWM
I use 29.050 Mc AM mode every day to talk with some fellow hams in the local area. My wife and I talk on 28.450 Mc USB fairly often as she is a "Tech" and hasn't upgraded, yet. (Sometimes I can beg her into talking to me on the radio when I go to the store or something. :-)
Every couple of days, someone who is DX to me will jump in to say hi. It's mostly E-skip from neighboring states at the moment, though....
Like CW Morse says, it'll really be busy when the new solar cycle gets started!
74IN said:
And the word is, the next upswing in the solar cycle is going to be very strong.
Link
I guess that just depends on the source. It is still being greatly debated about just how strong or how weak the next cycle will be.
What will cycle 24 bring?
This info was released approx. 4 months after the info in your link. I guess we will still have to wait until it happens to what will really happen. (Fingers crossed for a SSN of at least 150 :wink: )
For the guys that have not been on Ten during the peak of a cycle, it is awesome.
I know you have heard it before, but you really can work the world with a good mobile radio and 100 watts, and a lot of times you can do it with less. It used to be common to hear a lot of guys running converted CB rigs on Ten Meters with just the radio at 15 or 20 watts or so because it was a low budget way to get on ten and works great.
The cycle is bottomed out right now, but soon it will be on the up-swing.
It really is an exciting time for all of the new Ops that have the Tech Lic, if you like to work DX on 11 meters, wait till the cycle gets going....Ten meters rocks!
Most of the Exports cover some, if not all of Ten meters, and as long as the ALC is intact and Adjusted properly, you are set to rock and roll.
Even if you do not have the $$ for a big rig, a Converted Cobra 148, JC Penny 6247, or a Radio Shack TRC 448 with a bit of tweaking will get you on Ten.
Hang in there guys, it is comming.......
I have a European DNT CB that was converted for 10m. It was brought over for me by a British ham friend several years ago.It is FM only as that is what they run over there on CB and covers all of the FM portion of 10m and a couple hundred KHz below 29.0 MHz. It has about 5 watts out and has a low power switch which was required in England. On low power it is only 1/2 watt output. You would be amazed what 1/2 watt at the cycle peak will do.
Here's a few hints to help you when the new cycle DOES hit. It is meant to help, and not to criticize, OK? I know old habits are hard to break, but don't start (on 10 Meters) talking about "channels"! :D That is sure to get you, at least, gently corrected as amateur radio doesn't HAVE "channels" in the sense of CB. It's a dead give away to the OLD way of doing things! You are embarking on something NEW and exciting. You think 11 Meters was really sumpin' back in the day? Wait until you hit that rare DX from Zanzibar or the Australian "mate" down under! :D And, some of the old heads, the ones with a beef about the code "letting in the masses", yeah, they might criticize your lingo, of which "channels" is a sure excuse to get 'em to rag ya!
Don't get excited and forget and say "what's yer 20"? WOW! That's sure to get you jumped! :D Leave the 10-code behind.
Listen a bit before transmitting. Generally, talk the same way you talk on the telephone. 'What's yer location, mine is ------"
(yer LEGAL, so you don't have to hide! :P ) You'll hear "Q" signals such as QTH (home 20 to the CBer), or "QRZ" (often used on phone to mean "is anyone using the frequency"--not exactly accurate). QSO=simply a convo between two or more hams. Leave the "cutesy", folksy sayings behind you are accustomed to on 11M. Someone is likely not to appreciate it and will say something about it---hopefully, a kind correction.
"Fire in th' wire an' yer blowin' smoke" comes off on two meters as silly and unprofessional. :roll: There are no "first personals"
(OOF!) Use "my name is --------". "My handle is" is acceptable, too.
So WHAT'S wrong with CB lingo? On the surface, nothing. To a whole generation of CBers, this is an accepted way of "fitting in", making the group comfortable. It lowers the threat level by
taking the type of conversation down a peg and presenting the subject in a less serious way. However, to the listener, one who is not involved in CB or has no interest, it comes off as very silly and immature. Amateur Radio, to some extent, needs to represent to the public a more dignified face, a more mature "foot forward". It, after all, is still part of our Nation's emergency infrastructure and must show to the public that it is something that they can rely on---something reassuring. This is done with that more professional "face", the more professional way of speaking, omitting the cutesy and childish sayings (and, yes, we do have our sayings that have crept in--like "destinated" which is NOT a real word). Another reason for avoiding "CB-isms" is, our transmissions cover a LOT more territory via FM repeaters. One can make the SAME contact day after day, after day, after day. We don't know who might be listening and saying "UGH! Who is that silly goof that comes on every day talking like that?"
Back to the emergency comms. Another reason for "plain dress" language is the necessity of having the message get thru accurately! Using proven, even time-worn phrases is imperative to understanding the meaning of the message in an emergency. Being inventive, cute, or silly is NOT the way to save a life!
Thus, this is why you don't find "CB-isms" much on ham radio. To them, it is not "cool". That may or not fit with our perceptions of how it should be done, but it is the way it is. "When in Rome, do as the Romans do" is a good slogan. Listen. Use plain dress language. Talk the same way the other hams do, and soon you will forget about "channels" and "blowing smoke" :D To a ham, "blowing smoke" is a BAD thing; it likely means that something is burning up!!!! :( QUICK!!!! TURN THAT THING OFF!!!! :D
If you can do these things, your journey into ham radio will be a MUCH, MUCH enjoyed thing. I hope no one takes offense, it is not meant that way. Yet is is a reality that, if it is NOT said, some existing hams will NOT take kindly to the lingo of CB. We all need to be aware of this.
CWM
thanks for the great replies so far :D . every one has been helpful and informative and also very respectful . im assuming this is also a example of the type of mentality/behavour thats common there , im shure like everything there are exceptions here and there . thanks again......looking forward to more of yall's tips .
p.s. can i say yall's on there ? :lol:
When 10 meters is open, it is a great band but, it has not been open in awhile. About a month or so ago, it opened for about a week and I made about 45-50 contacts in the US. Now all I do is check into the weekly 10 meter net here locally.
Good advise Jerry but I have a problem. Whenever I use my converted DNT CB on 10m FM and say things like "QTH" and "five-nine-plus-twenty-over" it comes out as "What's yer 10-20" and "Yer blowin' smoke". Strange. :shock: What's even stranger is that everything I say into the mic comes out with a Cockney accent. :lol: Does my rig have a problem? :P
Fo-ten! Fo-ten! Fo-ten! Youre slammin' into the cherry patch on my receive! No cottin-pickin doubt about it, thats fo' duck-pluckin' sho', and i'm readin the mail..
