how to wire up a texas ranger /connex mic
Both radios should have the same wiring as a standard Cobra 4 pin mic - if I remember right.
Stock Ranger wiring:
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
If you are using a Ranger mic on the Connex; then use the above wiring.
Or are you using a different mic?
In fact, the Ranger mic should already work with the Connex radio.
