How warm?
Mr Clean
852
54
38
I have one more question. I live in indiana so it gets cold in the winter. I have an electric garage heater that hangs form the ceiling and will keep it as warm as I want. Can I get away with keeping it 50 or so when not in use or is that to cold? I know the newer stuff will be OK just wondering about the tube Browning and tube amps I have.
That temp should be fine but I would turn the heat up a little while before firing up the filaments in any tube gear.The sudden change in temp and thermal shock of the tubes can't be good.It may even cause components like transformers to sweat with the sudden change in temp.
