Howdy.
Oldtimer
223
9
75
Stuart Florida
I took the 2030 final and en1230 out of my Cobra 29 wx/nw/st.
I put back the stock final and replaced the resistor at R-56.
Now I can rx with no problem but when I key the mike nothing.
The meter in the radio doesn't move on rx or tx.
Any ideas?
Thanks
GOD BLESS
Does the transmit/recieve led change colors when you key the mike? Is the switch set to SWR or Calibrate? Just swapping the final should not have caused problems. Recheck all the connections and make sure that none are touching where they are not supposed to and vice versa.
BC
