"Hum" on input from radio to mixer
N0WY
Aug 11, 2010
13
Hey all,
I have waded into the land of dedicated audio equipment for my amateur radio equipment and am amazed by the reports I am receiving from others.
I do have one problem I have yet to work out and was wondering if anyone had any ideas...but first let me explain what I have setup, as I am sure that would be the first question asked of me.
Yaesu FT-857
LDG YT-100 Tuner
Behringer 1622FX USB Mixer
iPlus by W2IHY
Heil PR-781
Yaesu FP-1030a Power Supply
I am thinking the issue is that I do not have the power supply, tuner or radio grounded and I have heard that that could cause a hum. My issue is that I am in a 2nd story "office" in my house and running a ground that long would just turn it into another antenna.
So I am wondering what I can do to work on getting rid of the "hum".
Thanks so much,
Michael
I had a mean ground hum in my audio chain introduced by a Heil mic cable. In my case it was causing a ground loop. To solve the problem, I disconnected either the shield or ground wire from the rig side of the cable (I forgot which wire I removed but I remember it being obvious when I looked at the wiring diagram). The other thing to check is that all of the audio equipment is grounded to a common ground bus. Concentrate on the audio chain and you'll probably find the problem.
