Icom v8000 transmits when you change the channel
murphybrown
New Member
Aug 22, 2025
After a bad storm I plugged my Icom v8000 back in and it was doing a partial transmit, about 14 watts, swr on my external meter is showing 99.99. Sometimes the radio works ok. Then sometimes it will start the 14 watt thing and run the fan or if you change the channel it will go on and off between channels. It also does this with the mike unplugged and the speaker unplugged Any ideas on a fix. Is it worth spending money on or should I look for something else. Antenna and coax look ok, I am replacing the gas tube in the protective device today.
Thanks for any help
Chris
