inexpensive/cheap cb amps . palomar/cobra vs. rm/kl
That 300P is a fine amp if not overdriven. Set DK to 1.5-2.0 watts and let it run. A single final radio is best for this amp, however I have used dual-mosfet radios with this too with success. If you could keep the radio PEP @ 25-watts or less, you'll be fine.
Those blue face Cobra amps are supposed to be nice class AB amplifiers. If they could sell well on Evil-Bay I would love to buy 6 and sell 5, then mine is free.
I couldn't tell you what they are using in the KL-503. I sent RM Italy an email a couple weeks ago asking them, and here is their reply. Of course they are in Italy, and the English translation is not great, but here is what they said:
Dear sirs, we usede N.9 special transistors make for us!! Regards rm@rmitaly.com
------Messaggio originale------
Da: Jim
A:rm@rmitaly.com
Oggetto: KL-503
Inviato: 28 Set 2010 07:26
Hello,
I am interested in buying one of your new KL-503 amplifiers. Could you
please tell me what type of RF transistors are used in this unit, and how many?
Thank You,
Jim
KL503
You are right, They do use mosfets. an RM 4 driver and RM3's in the final.
A wild Arse guess is that the RM-3 is a re-badged IRF520 and they use 8 of them.
We will have to rip the lids off one of them and take a photo!
cheers,
Dave
i have owned a KL300p before and they are a "not bad" type of amp.
did about 150 to 180 watts PEP depending on input. it liked about a 1.5 to 2 watt deadkey.
they are class C, so SSB doesnt sound the greatest, and i found the SSB delay to be not quite long enough.
believe it or not, these things actually have a sub-par low pass filter built into them. not sure how well it worked, but it is there.
it did run hot, but never burnt out on me.
there is one MAJOR downfall to these amps IMO though.
the receive pre-amp is ON ALL THE TIME when the amp is on!
to me this was beyond annoying, as it ruined the great receive of my radio.
(we all know linear amp pre-amps are not the greatest)
i added an extra switch and made the pre-amp switchable, increased the SSB delay a bit, and the amp worked fine for me until i was tired of it and raped it for parts. LOL
the pre-amp thing alone would be enough for me not to recommend one to anyone.
i have not owned the cobra amp, but i would make damn sure its the class AB style with a built in low pass filter and not some cheap copy in the same case before i bought one.
(copper fooled quite a few people a few years ago with their palomar 225.
people thought they were getting a great deal on an AB box and ended up getting a bare bones class C 2x1446 amp)
if it is the "real deal" cobra AB amp, then its basically the same on the inside as the palomar 225 amp that you and i both have.
good luck,
LC
KL503
Without seeing the layout it does resemble a pair of KL203's with a driver.
I kl203 will do 160-200W PEP on SSB so I guess the KL503 should max out around 320-400 depending on frequency. Like the 203 it will probably only work well from 18-30mhz as on mine the input SWR rises to 2.5-3 to One on 14mhz.
Still put out some signal but it may affect the drive radio.
from 18mhz on up no problems.
cheers,
Dave
kl503 with mosfets
Could someone post a picture of the insides of this amp showing the transistor layout.
How does it go in SSB?
Anybody used them around 11m on SSB yet?
be nice to know cos they are a nice price.
cheers,
dave
