Install
Ham Radio Nerd
Apr 14, 2002
9,358
2,090
383
Re: APARTMENT BUILDING INSTALL
HRO sells a "window jam mount" or something like that. It goes over the window sill and is held in by the window. I have looked at it personally in the store and it looks like it will work good. No drilling required. You can use whatever stud you like...could even put a 102" whip on it. If you use a 1/4 wave antenna, you might have to figure out something for a groundplane. A 102" wire attached to the mount and dropped right below the antenna might work pretty good.
</p>
The mount I described angles the antenna out away from the building. It could be used on a railing or in a window jam. Sounds like that's your best bet. Go find it at www.hamradio.com. Look in the online catalog, in the antenna section.
</p>
Why not just use some C clamps to the rail ?
<hr />73, Mike
</p>
Why don't you use the mount I told you about? Just drill into the rail right through it? Use a 102" whip. Metal railing = Groundplane problem solved.
</p>
Canadian Dollars???
cost appox 90 US
(plus shipping)
90.00 USD
United States Dollars = 107.873 CAD
Canada Dollars
1 USD = 1.19859 CAD 1 CAD = 0.834313 USD
CDX 339
RadioActive
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=audioshockwav>AudioShockwav</A> at: 11/9/04 6:31 pm
Just get a L shaped mirror mount bracket and bend it so it's pointing away from the rail. Then drill and mount it into the rail.
</p>
They have the L mirror mount bracket at every truck stop. And on about 40 different websites....
</p>
fill us in...inquiring minds want to know....
<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/tongue.gif ALT=":b">
</p>
I currently have a serious problem with an antenna install, I live in an apartment building and want to install a balcony rig, but i cannot drill or mar the finish.
I also have someone living above me and below me, so installing something huge is not an option. The biggest i can go is 102'' on an angle.
Please help me figure this out
Thanks
927 Duane<img src=http://users.joplin.com/dutch64804/posticon43.gif ALT=":43">
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=cqdxcqdx927ontariocanada>CQDX CQDX 927 ONTARIO CANADA</A> at: 12/5/04 6:59 pm
