Insulating washers.
Crusher
May 12, 2007
841
405
Louisville, KY
Can anyone tell me were I can get replacement washers that are either nylon or plastic. these have to have the little ringthat fits inside hole. these are used in power supplies or in this case I am repairing a motor maul and one of the washers is split and I don't trust it. It has a 3/8 inch bolt that goes thru it with that extra lip so to speak. ( same kind of washer used to insulate your mounts for you antennas only slightly larger). Anyone have any ideas were I might find parts?
Thanks in advance.
Crusher
These are called 'shoulder washers'........
Google for them....be ready to do some homework. They
come in a gazillion sizes and materials.......
Maybe someone else has a more direct approach(a supplier?)
Good luck..............Ol'Ben
Thanks BenDare, i found a supplier that I can get them from. Wasn.t quite the right outter diameter, but close enough. I couldn't beat it for the price. ThoughI did have to buy 300 of them to get them ($15). Guess I can build a few more power supplies after finishing this other project. Well after the braek this weekend.
