Intermod on dual band mobile radios
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
I have noticed if I am scanning the right side with Air, Local PD, FD, EMR and so on if the Key tab is on the LEFT where Ham VHF UHF is used to Transmit, The right side suffers from Intermod. Will this solve the problem: PAR VHFDN152 Filter ?
Read the advertisement. It says it will 'notch' out the 150 Mhz range, so, you won't be hearing it anymore. IMD would be a factor is you were transmitting on the 150 Mhz range, but not if you are just listening.
