is it bleed over or something else
1iwilly
Sr. Member
Dec 7, 2008
916
655
103
64
ok so my 148 gtl side mike and cobra 2000 gtl both have exit13 NPC mod
they sound good when monitoring on another radio all limiters are intact mike gain I've always run them at 1 or 2 o'clock position while I was on the 148 on channel 8 I can hear splatter on channel 9 but not on channel 7
then I switch over to the 2000 and the same scenario 1 channel up yes 1 channel down no issue also it doesn't matter what channel you use it's always 1 up with this issue I went from 12 o'clock on the AMC pot to close and it fades away maybe because the radios are only 3 feet away from each other 1 on an antenna other on a dummy load. thanks
Reactions: Rwb and Handy Andy
The external speaker wire is acting as an antenna then feeding into your radio. I had the same problem with cheapo computer speakers in my workbench. I did not have any type of feedback issue until I put a second radio in to use to monitor myself. Then feedback issue started. My conclusion was push the power button on the speakers when not using them, I only drew this conclusion after chasing a problem that did not exist. Someday I will buy better shielded computer speakers.
Reactions: Rwb and Slowmover
could be that is because there is a jump between 7 and 8 and not 8 and 9,,,,,, there is a r/c channel inbetween 7 and 8,,,,
CB Frequency CB Channel Customary Use
26.96500 CB Channel 01 open to all
26.97500 CB Channel 02 open to all
26.98500 CB Channel 03 open to all
27.00500 CB Channel 04 open to all--4x4 channel
27.01500 CB Channel 05 open to all
27.02500 CB Channel 06 open to all
27.03500 CB Channel 07 open to all
27.05500 CB Channel 08 open to all
27.06500 CB Channel 09 Emergency
27.07500 CB Channel 10 open to all--regional roads
27.08500 CB Channel 11 open to all
27.10500 CB Channel 12 open to all
27.11500 CB Channel 13 open to all--marine, RV
27.12500 CB Channel 14 open to all--walkie talkies
27.13500 CB Channel 15 open to all
27.15500 CB Channel 16 open to all (also SSB)
27.16500 CB Channel 17 open to all--North/South Traffic
27.17500 CB Channel 18 open to all
27.18500 CB Channel 19 Truckers--East/West Hwy Traffic
27.20500 CB Channel 20 open to all
27.21500 CB Channel 21 open to all--regional roads
27.22500 CB Channel 22 open to all
27.25500 CB Channel 23 open to all
27.23500 CB Channel 24 open to all
27.24500 CB Channel 25 open to all
27.26500 CB Channel 26 open to all
27.27500 CB Channel 27 open to all
27.28500 CB Channel 28 open to all
27.29500 CB Channel 29 open to all
27.30500 CB Channel 30 open to all
27.31500 CB Channel 31 open to all
27.32500 CB Channel 32 open to all
27.33500 CB Channel 33 open to all
27.34500 CB Channel 34 open to all
27.35500 CB Channel 35 open to all
27.36500 CB Channel 36 open to all (also SSB)
27.37500 CB Channel 37 open to all (also SSB)
27.38500 CB Channel 38 open to all (also SSB, LSB)
27.39500 CB Channel 39 open to all (also SSB)
Not to get too technical, but you may hear terminology like...
- 60dB down at 3kHz...​
Or...
Image Rejection - 65dB
These refer to a way the receiver responds to the noise present on frequencies close to and near the frequency you're tuning into.
Your Cobra 2000 has this to say about it (Its' on Page 7 of your owners manual)
In trying to get good SENSITIVTY and good SELECTIVITY - they tend to "Walking Contradictions" you can't have both without one them interfering with the other...
So along comes RF Gain, the "Great Equalizer" - its' concern is to allow one method, to achieve it's goals and yet allow the other to do some work to help it achieve it's own goals.
Referring to -
Selectivity - your bandwidth to receive a signal depends on how good the steps of filtering is.
The more steps or stages of filtering, the greater the level of attenuation around and AT the frequency of interest.
As a level of caution:
  • You can have too many stages of filtering - where even the signals you want to receive can't get thru all the stages no matter how much amplification is applied to the original signal arriving to the antenna - including all the noise around it and embedded in it.
This is Reciprocal - it affects another approach, or aspect:
  • You can also have Sensitivity problems - for then the signal and its' noise the receiver "captures" together with it, then is amplified together, along with any other signals that are strong yet not exactly on the frequency.
  • The radio processes the RF signal as a method of mixing the received signal to a local signal to make an IMAGE of the ORIGINAL signal - but at a different - lower frequency that can be amplified to a higher degree of accuracy than your RF signal can be if left alone.
  • Mixing to get an IMAGE inherits the problems the original signal had - it's noise, any interference from frequencies close to the selected frequency - SEE ABOVE - will also be included.
So what you're hearing, is the "bleedover" you have as a factor of overload. You can swamp the receiver close by with the images as well as the sheer strength of RF signal present at the other radio - into the radio you're monitoring - thru several methods listed above and then others that are more related to a "rectification" of the signal thru the Monitors radios own Audio Amplifier circuitry.
You can determine the path or method used by simply moving or separating the radios apart and use a dummy load on the monitor radio to help balance out currents that can form thru it's shell, or skin - that can interfere of generate the effect because the shielding the case provides is simply overloaded and can't isolate the receiver from it.
One other factor is the REJECTION - the ability of the Receiver to "knock down" the Gain that the RF Gain is not able to do, and attenuate ALL signals arriving to the radio's receiver (A figure of Merit as performed by the AGC) but in doing so, leaves behind an "image" itself - that being the received strong signal - mixing as an IF image because the AGC is working at rejecting the very signal causing the strong image to appear, as if it is mirroring the signal like an Echo.
thanks, andy forgot about the front end overload but the problem is fixe took the external speaker with the cheap thing wire out move the radio a tad away from each other at the end of the day we get overload with things on our minds that at the time we oversee the simplest thing in from of us
    Scheduled for Jul 4, 2026 Saturday Live Streams:
    To celebrate the 250th birthday of our great nation. We are giving away not just one, but multiple antennas! The Grand prize is the CaHR-Tenna Hydra Antenna, along with several other antenna prizes that will be announced throughout the giveaway. Whether you're a new ham, portable operator, POTA activator, or an experienced HF operator, this is your chance to upgrade your station. Prizes Include: HRA Hydra Antenna (Grand Prize) Additional antennas from HRA More prizes may be added during the giveaway!
    CQ Worldwide VHF SSB/CW Contest: 1400Z, Jul 4 to 1400Z, Jul 5
