Is this correct ????
  • Thread starter Thread starter Bandit169
  • Start date Start date
B
Bandit169
Guest
Okay, here goes. A buddy of mine just told me this. He said that he was told to run 24ft of coax from his antenna to his Kicker and 12ft from the kicker to his radio. Now he was told that 36ft = 1 wave length. And with that configuration he should be able to talk up to 50 to 60 miles from his mobile. IS THIS TRUE TO FACT OR IS THIS BULLCRAP ? PLEASE LET ME KNOW. Thanks and 73s to ya'.
73s To all&Down an'out for now,still aMUDDUCK Quack,Quack.Bandit169-CDX169
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=bandit169>Bandit169</A> at: 1/30/04 6:50 am
coax length does not make a difference in how far you can get out on your radio. old myth. however, easiest way i can explain this is to get correct SWR readings use coax lengths in 1/4 wavelength's so your friend is partialy right 36 feet would be a good length to use although it would not make a difference were in that 36 feet you put your amp.
</p>
</p>
Hi guy's,
Thank you for the correct answer to this little question of
mine. I myself thought in the same lines as both of you.
But considering the fact's i figured the best way to answer
my buddy would be to post it here. Knowing that there are
are enough radio wizards here to back what i thought.
Or inform me if i was wrong. Again i say to you Thank you
and 73s to the both of you. And may the Power of Radio
bring some of the best Skip into you receive.
QUACK,QUACK !!!
</p>
Hi guy's,
QUACK,QUACK !!!
</p>
