J pole and ground
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
I want to get my j pole high up.
At the moment its well over 25+ feet. I would like to mount it 15' higher I have it mounted to a stainless steel vent pipe on the peak of my roof its than attached to a wooden pole. I have a 15' steel piece of push up pole does the j pole need to be insulated from the metal pipe ?
Sent from Outerspace, on the DarkSide of X.
Makes no difference with a j-pole whether it's isolated from the mast or not. you also don't have to ground a J-pole unless you're worried about lightning.
Kew thanks man.
no lightning
here sono worried about that.
