jobcom jmx-450 radios
john52732
Apr 28, 2009
13
I have these 2 jobcom 450 handheld radios there were used by an local company here with a repeater I think they dont mach up to each other I found some programing info on them but dont really understand it the radios say they work fro 450mhz to 470mhz so I think they would work on frs band they are 3 watt I looked them up on ebay they sell for 149.00 each new what should i do with them I tried them on ebay but know one wanted them here is the site with programing info http://www.soden.com/jobprgm.html
JOBCOM
I have one and have it programmed on the GMRS frequency, it wont program on the FRS frequency, just GMRS.
I would put them on for sale if you dont want them on qth.com, or GMRS Yahoo group.
Or if you want to use them on GMRS buy a base unit for $129 <red dog radios>, and use them that way.
You can also look up GMRS directory and to see if there are any repeaters in your area and use them that way..mygmrs on the net.
You are suppose to have a license for GMRS......
I would check to see about the repeaters in your area if there are any.
DOCTOR/795
Update I was able to program them to grms and they work as a pair now and very well I might add I dont have the right charger for them so I was wondering what the proper voltage for the charger you have for yours is doctor
CHARGER
My units came with a charger
It says
RITRON INC
BATTERY CHARGER DV-1010L
INPUT..120VAC 60HZ 5W
OUTPUT..5.5VDC 100MA
HOPE THIS HELPS
DOCTOR/795
CHNL 16 LSB
SUPPORT THE FCC...TALK SKIP
GMRS
GOOD DEAL.
I was on GMRS Saturday<nothing around here>, in Indianapolis, some activity and I got on a repeater and more activity, actually enjoyed it. The repeater has a great coverage some 40 miles so not bad.
DOCTOR/795
Ritron Radios 450 mhz
Hey guys, just wanted to let you know. The manufacture is in Indianpolis. These radios are generally used on golf courses with Rain Bird irrigation systems. They work on the Rain Bird Freedom System Repeater. You may post the radios on Turfnet.
If you know anyone I have 3 Ritron 450 radios that sold new for $650. I will take $150 for each, including chargers. They can also be programmed at 450-470 mhz. They are used primarily to turn on irrigation remotely when riding around the golf courses or commercial site.
Hope some of this was helpful.
  • @ heartbreaker3473:
