johnson messenger 250
Hello, did you ever find info on your Johnson Messenger 250 mic wiring? Let me know if you did, I can't find any info on it and so far only the brown, stock hand mic will operate the radio. Thanks much
has anyone come up with a wireing code for the messenger 250 to a 4 wire turner+3 desk mic i know it will work, i had the same setup it was my first base station in 1960 a 4 wire turner +3 desk mick and a 250 johnson.
It states it is a code "S" radio which requires the use of certain turner microphones to work. The attachment speaks to this-
