Just picked up a EFJ Messenger 223
jeffmassey
Jun 4, 2013
11
columbia,mo
Hello! I am new to this website,and am already glad with what little I have seen.Kudos to the originators!Anyway,I found a "223"in a secondhand shop.Looked at it here at home and found that it may have been dropped:mike connector is cracked;volume knob cracked;S-meter is pinned,and has a short circuit somewhere.It has the diode MOD in place of the rectifier tube.I used a lightbulb "fuse",then an induction motor to supply soft startup current to the radio and found the short.Found schematics here,will use them to Divide and Conquer(SIC).If I can,I will track my progress or Con-gress to either a vintage receiver or Boat Anchor.:bdh:
Also have a Radio Shack TRC-47 23CH W/SSB.
UPDATE-found the short;was the diode MOD.Installed only one diode,B+ restored.No receiver hiss,just low level hum.
UPDATE PART TWO-on a hunch,tested the voltage on synthesizer board,only -6V.Replaced filter cap,now have -12V and hiss.Turned channel knob,hiss changes with frequency.Will check to make sure both oscillators working next...
My very first SSB rig was a TRC 47. Every review I have ever read of them said to avoid it so of course I had to have one. It really wasn't a bad radio for what it was. As I recall, a couple of 10 microhenry RF chokes soldered into the clarifier leads would give about a 12 kc slide.
Pretty cool old rig, Mr. Massey! Glad you're getting her back in working condition. From what I understand, they can have really LOUD transmit. Do you have the matching desk mic with yours?
73,
RT307
Thanks for the replies!No,unfortunately the mike was not included. Good 2 know about the TRC47.
UPDATE3:The Messenger spoke its first words last Saturday!!! I am hopeful that,with my limited amount of test equipment, '223 will make a fine receiver. The transmitter may take a bit longer...:thumbup:
Also have a working Heathkit VTVM and a frequency generator.
Just picked up a EFJMessenger 223
Thanks for the AD,2 World Radio! It thrills me sometimes when I find a diamond in the rough such as this.I am currently getting an EICO 667 tube tester which should help bring this project along.More thanks to BooBoo Sims...
    357 has joined the room.
  • @ 357:
