klv 1000
joespunn23
Jul 27, 2010
30
central new jersey
good day everyone i went to a local flea market today was looking around a there was a guy who cleaned out peoples house he had what he thought was a pa system but it really was a klv1000 well i got it for like 25 bucks it had the cover off and it looks like it was someones project since it looks like they thought it was the tranfromer due to all the wires from the transformer were all discontected it looks to all be there as far as the tubes transfromer coils ect. and still put together other then the transformer being unattached if it is the transformer will this be fesable to fix or will it cost to much ??? also if it is worth anyone know of someplace in the new jersey area to get it worked on thank you joseph kd2aag
i tried to take a pic with with my phone but only one looked ok so ill post that one ill take some pics with my digital camera tommrow
hello everyone well i finally too some good pics maybe to many as i was taking pictures i noticed a couple things that looked wrong i was on the transformer it self there were three 3 that looked burnt and had wire showing were the jacet had worn off ,in the pictures i tried to mark out the bad spots photo shop so im not all that great with the computer plus bear with me on that actual names of the parts im explaing thats why i tried to highlight the area im discribing thank i notivced that i had to remove the top board from the top of the tubes i notice that there 2 screws took out one with easy but the othere on started to spin the coil that was under it so i held it and got the creaw out this plastic seem to be very britile o guesss from getting hot causr the underside of the board looked to be burntalso highlighted this in the pics . so after looking i would like an opioun if this thing is worth fixen thats for all of your time joe kd2aag
greetings
for some reason your pix are not showing up, they may be too big. when you upload in your 'manage attachments' window, it will let you know there if they were not uploaded due to the size. hope this helps out else others will be along...best of luck with the amp
thats exactllly what happen i can not figure out how to make the image smaller i tryied to use one program but couldnt figure out how to use it :confused: any one now of a very easy to use program or way to make pictures smaller thanx kd2aag
Check the settings on your camera. I first got a "real" digital camera a couple of years ago. The factory setting for the resolution was insanely high - one picture was about 6MB! I checked the camera documentation (Nikon Coolpix 4000) and changed the resolution to about 28-30 KB. I can't see any difference with my old eyes, but it's a lot easier to email pictures with the smaller resolution.
pictures for the second time
i do beleive i have them uploaded this time
set of pictures part 2
i was able to upload i know there are a lot pictures , when using the forum was that th4e right way to upload large amounts of pictures , i didnt know if there was a proper proceecder such as putting in a zipp file ect . i like the forum its a great source of infromation and everyone is so helpful it is a great hobbie that we all belong to kd2aag
You got a heck of a deal there for $25!
The tubes alone are worth $100 for the 5 used ones.
That insulation is most delecate on those heavy wires. Tape up the bad spots.
Re-install that tranny and see what comes on. Tube filaments, panel lamps?
At least the fan on the back?
