lazyboner antenna
Lazybones1222
Apr 6, 2005
948
29
Tampa Bay Florida
Lazyboner - haha. I wish. Then I wouldn't get in so much trouble.
If you meant my antenna:
Lazyboner antenna link
You can get them @ radiowavz.com or ebay.
At radiowavz.com they only show ham dipoles but he does make the 11 meter one too. Call him. I got his cell phone # if you have problems getting him. He is a ham, and pretty patient and helpful.
On ebay, do a search on: best CB antenna
It is called a double bazooka dipole, 1500 watt version around $29 us, 5000 watt version ~ $39 buy it now on ebay.
<blockquote>Quote:<hr>from the South <hr></blockquote>
By the way, I live around Atlanta but I am FROM Pittsburgh. Bah haw haw
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=lazybones1222>Lazybones1222</A> at: 1/20/05 4:03 pm
I used 2 1/2 PVC sleeve and Pipe to make join to an existing roof vent to make the mast shown in the pic link above. Set it at a @ a 90 degree angle using 1" pvc pipe as a spreader. Whole thing is only a few pounds.
To tune, they are usually a little long -
(hard to make them longer) just fold the wire back on itself to shorten antenna and zip tie.
I had to shorten each side about 1/2 inch to get a SWR of 1.1 on channel 20.
I did not cut - seemed too permenant, kinda like a vasectomy. Ouch. <img src=http://www.wwdx.org/smilies/posticon5.gif ALT=":p5">
</p>
homemade antenna thread:
[link=http://cbradioforum.com/messageview.cfm?catid=7&threadid=15346 newwindow]click here[/link]
I'll see about a better pic. <img src=http://www.wwdx.org/smilies/posticon60.gif ALT=":60">
</p>
where did you get it again? and what is it called..
the thing on your roof..
</p>
Hey Me, check out the connections inside the coil assembly, i remember a review that identified a production joint that was not soldered, i think were the feed came in to the base, not sure if you will butcher the antenna or not to get to it ???
worth a shot tho.
best of luck
<img src=http://home.comcast.net/~shockwav/greatbrf.gif ALT=":*cacflg">
26 CDX 757, One of Our Subs - subs757
mobile with RCI2970 Astatic575 Sirio 7/8th @120w back at base Yaesu FT757GX Datong FL3 filter Astatic575 3ele Sirio yagi @130W
More than 2000 people are injured by teapots each year in the UK !</p>
