LED Lighted Callsign Display
Riverman
I Support WorldwideDX.com!
Nov 12, 2013
3,080
3,466
273
These aren't for everybody, but if you like these kinds of things this one's really nice.
I got mine for Christmas!
It's about 5" tall, cost $30 and came from www.HamCrazy.com
Works with a rechargeable battery (included) and comes with a small remote control and a USB cable for charging the battery.
Can adjust brightness (a little) and choose between fifteen different colors or have it randomly go from one to the other.
The pic doesn't do it justice. The colors are really pretty in person.
So if you have a space to fill, this might be for you.
Another cool thing about these is that if you are using an end fed antenna, when you key your mic the display lights even when it is turned off. Can't use ferrite cores, a balun or choke because that eliminates the "other half" of the antenna.
Back to the drawing board. I can hear BJ laughing right now. :whistle:
Reactions: Redbeard U812
Does that end fed cause the ballasts in fluorescent lights to shudder? Or the lights to come on even when off?
