Linc 2 plus ghost
Ziploc
Mar 19, 2016
299
136
53
54
Linc 2 plus owners , weird stuff going on when Un keying the radio with running power channel changes down 1 own it’s own? Doesn’t always happen but does it enough to drive me nuts. Stray RF ? Any help appreciated
I’m not sure it did it stock . The only thing I noticed with the stock mic is that there was a lot of times a delay after key up to talk. The Skythumper mic on there now is worse
I had an issue with a aftermarket microphone on keyup it would change the channel every once in a while. Didn't happen with the stock microphone. Rewired the mic again and didn't have any problems after, so not sure in my case if a stray wire stand was hitting the up/down pins or what.
I'd test out the stock microphone and see if it happens at all, then you can determine if it's an issue with RF or just that particular aftermarket microphone.
I also had a delay issue with e RCI2950DX a while back and a aftermarket microphone. I believe it was solved with a resistor someplace. There was a thread on here about it years ago.
Reactions: Ziploc
