A Winner has been selected for the 2025 Radioddity Cyber Monday giveaway! Click Here to see who won!
Hi all i have a Maco 200 amp and on the back is a place that says match and looks like you use a plastic screwdriver to turn it. Is this a antenna match? If not what is it for and how do you use it? Thanks God Bless.
Yes should be. Many of the tube amps with a rear adjustment is for SWR tuning. Wether it is for the radio side or antenna side ...... depends on the amp.
Hey Thanks! And yes it will be in a dummy load I looked on line and did a search for it as well and just could not find anything at all. Your right this is a good amp. This amp will cost along on the low side at 180 watts all day long and will swing 380-400 on high. more than i need most of the time. Well Thanks for your help and to all.
