Magnification?
338_MtRushmore
Sr. Member
I Support WorldwideDX.com!
Jun 17, 2012
1,658
1,176
193
Spearfish, SD
What do you all use for magnification for working on through hole board type of work? Net necessarily smt type of microscope but thinking loupe glasses or something. My eyes have gotten to the point readers just don't cut it anymore.
I hear you fellow aged-eyes!
Reading glasses from the dollar store - 1.25, 1.5 and 2.0. I also have eye loupes, 4x, 7x and 10x and "der Kaiser" for checking phono stylus - 30x
The best I have found is a modern digital video camer on an old drill press stand. a cheap flemarket monitor and a steady hand. zoom in with camera you can zoom in and out. I have seen this done but have NOT done this myself. He used a drill stand that had a clamp the went around the had drill (not used anymore). He discarded the old hand drill and mounted the camera into the clamp. He couls zoom in on a chip cap, inductor, resistor and make it very large. The numbers were very plain also.
73 Old Barney
Invaluable tool for general close viewing.
For closer work, I use this thing...
The tool can be taken from the stand and placed onto a board, trace or anything. It has adjustable focus and dimmable lamp. It's not sufficient for smd "work" but to see up close and id components, locate cold joints/broken traces, find shorts, etc. It was pretty cheap on Amazon.
Any idea the name or model?
The magnifying lamp, Dazor 8ml-104-w, I picked it up years ago from a jewelry store that closed.
The digital microscope is a skyear brand, that particular one is discontinued, here is the similar model on Amazon...
Edit to add, I'm not terribly concerned about brand, as long as it has clear images and lasts a long time. The microscope is battery operated, rechargeable, it has only had to be recharged a few times in over 2 years, has worked great. The mag lamp uses fluorescent bulbs, I found a stash of them cheap and stocked up. I have only had to replace the bulb once in almost 20 years though.
I was going to hang it up until I found these. Comes with 5 different lenses.
Without them, I cannot read a book. With them, I can do anything from carb cleaning to soldering 0201 parts. $30 changed my life lol.
Reactions: VMC
On the highest strength lens, it is about 6", but I find myself using the 2x ones (which is more than a 2x reader) and I can see my whole desk clearly. Out of the 5 lenses I have, I only like the 3rd one (labeled 2x) and if I want it zoomed in more, I move it further away (two attachment points that both move).
It is certainly NOT like having a 100x zoom microscope on a big 4k monitor, but I am almost glad its not because I would get dizzy. I just stick with the one lense and if I need to do something extremely fine, I flip down the loop and get in close.
Not perfect, but IMO, great for the price. Your eyes may vary..
I use a magnifying lamp with built in light like cable guys pic. That combined with el cheapo 2x reading glasses. Have a 30x loupe if I really want to see whats going on.
Another vote for the electronic microscope as in cable guys pic. It was $35 and makes the difference between being able to handle SMD soldering or not at all. Also helps a lot by being able to read tiny descriptions on parts or inspecting boards for bridges or bad soldering joints.
Reactions: 338_MtRushmore
I started a job in appliance repair recently, and today I was trying to read a board on a Samsung refrigerator. Even using my phone zoomed in was nearly impossible to read. The kid with me claimed there were pin numbers on the connector, but I never could even verify markings, let alone identify them. Just ordered a bunch of options to try, so hopefully something will work out, because this is ridiculous.
Thanks for all the recommendations
