California..those are channel changing buttons by the way..What state are you in?
The little triangle on either side of the M in Magnum are the channel up/down buttons.Yep that be it .does it have up and down buttons on top ? And how much you want for it ?
The little triangle on either side of the M in Magnum are the channel up/down buttons. Thanks for the information..
I sent you a message last night, you get it ?Good to hear! I was unsure if they were volume or channel. Private message me if you are able.
Found a mic locally, thanks for the help...I sent you a message last night, you get it ?
The stock Magnum mic is a power mic. If you pop the back cover off the Volume pot is right there.Good to hear! I was unsure if they were volume or channel. Private message me if you are able.
You don't happen to still have that Magnum mic do you?Good to hear! I was unsure if they were volume or channel. Private message me if you are able.
