Magnum S45HP (OmegaForce) very low Modulation on SSB
tuner
229
41
38
Canada
Hi Guys,
I did my best to research on here for a remedy but, no luck.
Here goes, just recently received my S45HP brand new from ebay.
turned it on and noticed no mods done, which is fine. I opened it up to move the jumper to con3 for 10 and 11 meters. I noticed no jumpers so I researched a little farther to find I must remove bridge for con1 and solder a bridge across con3. Everything is good, I am very happy with am on 11 m. I then tried usb and lsb and I have hardly any modulation.Has anyone had this problem ?
Any info would be Greatly Appreciated
Tuner
The CB mod doesn't matter. Sam knows 99.99% are modded. As long as you sent in your warranty sheet and/or you got your receipt, they will fix it.
If you used a propane torch and scorched the board and left 2 ounces of solder blobs all over, then they probably won't fix it under warranty.
Just call 'em up.
