Precisely!The s9's are nice and stable if tuned NOT for maximum output, you over tune and u start having TX problems. i'd keep the amp and save up for a magnum radio.....IMOgood luck
I wouldn't go that far. Peaking a resonant circuit allows it to operate more efficiently, and do it cooler. Radios from the factory are some times not shipped as spot on, but are "good enough" and can benefit from a peak and tune ........ which is not to be confused with a "hot rod tune up".Peaking and tuning stresses the radio.
really?Peaking a resonant circuit allows it to operate more efficiently, and do it cooler. .
True, if you're looking for maximum efficiency at a specific frequency, or if you operate in a narrow portion of the spectrum. But if you want the maximum bandwidth that the radios are capable of, I prefer to leave them stock. Since I operate on the whole of 10M, as well as the CB, I like my radios fairly broad-banded. I have never noticed any deficiencies in TX power or receive sensitivity in my stock radios. I have found that peaking a radio narrows the bandwidth.I wouldn't go that far. Peaking a resonant circuit allows it to operate more efficiently, and do it cooler. Radios from the factory are some times not shipped as spot on, but are "good enough" and can benefit from a peak and tune ........ which is not to be confused with a "hot rod tune up".
You may be right, I'm no radio guru. But I'm thinking the Q of the circuit is already build in and peaking the resonance *shouldn't* make the circuit more narrow. But that's a guess.True, if you're looking for maximum efficiency at a specific frequency, or if you operate in a narrow portion of the spectrum. But if you want the maximum bandwidth that the radios are capable of, I prefer to leave them stock. Since I operate on the whole of 10M, as well as the CB, I like my radios fairly broad-banded. I have never noticed any deficiencies in TX power or receive sensitivity in my stock radios. I have found that peaking a radio narrows the bandwidth.
That would work. Make sure that the Texas Star is a high-drive, 4 X 2879 job. Try and keep the output of the S9 to around ~30 W PEP for best quality.I agree, I would keep the T.S.500 and buy a Magnum Stock S-9 40-50wt. radio and match it to the Amp. JMO.
I don't have an S9-175 yet; mine is on order. However, it is microprocessor controlled, and I have not heard any complaints about the stability. I intend to use mine on both AM and SSB. Since it has many of the same features as the S45HP, it should be winning performer on both modes.
In reality, I need these 10M/export radios like I need a hole in the head. But my buddy Mike, VA3MPM and I have a friendly competition to see who can collect the most big 10M radios. This is a running joke with us. Not sure who's winning. We both have S45HP's, Superstar SS158EDX's, General Grants, HR2510's. He has several AT5555 variants (two AT5555 and two Alpha 10 Max 1000). I have one, and we are both ordering the CRT SS69000 (because it's cheap). We both need that rig like we need a stroke!(You can never have enough 10M/export radios!!!) I will have the S9-175, and the RCI Ranger 69FFC2, which he does not.
I will have all my 10M/export radios set up on a separate desk with a hutch/shelving unit to hold all the radios. The bottom line: He who dies with the most radios wins!We are both highly experienced hams (me, 42 years, him, 25 years). Some locals hams think we are deranged, "playing with those CB's!!!". Yeah... it's called fun! They should try it some time! (Bunch of Pecksniffs!)
This does not include my amateur radios - several HF transceivers, 6M all mode radios, 2M all mode radios, and lot's of AM boat anchors, big "heavy metal" rigs, boat anchor receivers, big high-power AM transmitters, and some broadcast rigs, tuned to the ham bands. etc. Lot's of gear!!! The shack fills up my entire basement rec room, with three large desks full of gear, tall 19" racks, etc. (Pictures to come.)
Would be happy to. I also have a new RCI Ranger 69FFC2 which I have to install. We'll review that one too.Ed, when you receive your S9-175 would you do a review on it. The only review I have seen on youtube only goes to the description/features rather than a working review. Bruce
