You will kill that amp with an S-9 no matter how low you set things.
I don't know about that. If I can push an RM Italy 503 reasonably with an Optima I would figure a 2 x 2SC2290 can handle 15-20 watts SSB like 222DBFL referenced.
(for reference use ~8 watts PEP on the 503)
I would pretty much ignore the High Drive reference unless in fact the 15 watts in was producing extremely low numbers.
ETA: Yeticom Optima with 16 watts pushes a 4 x SD1446 to 320 comfortably.
Where should I run the rf power on this radio to run this amp on ssb?
BJB, the RM Italy amps are not bad, the issue most have with using them is over driving them which causes "splatter" and most likely failure. They don't require much power to work properly. a 1-2 watt dead key and about 8-12 watts pep max is all that is needed to power these amps. Your uniden grant would be the better radio to pair with an rm Italy amp, have the dead key turned down or have a variable power installed. The magnum is just too much power even at it's lowest power setting. If you have a bit more money to spend you can get an amp that can be used with either of the radios you mentioned. Something like the tnt 350hd, or a Dave made 2 transistor amp would work well with either radio mentioned. If you use SSB then make sure to have the Dave made amp have an added SSB switch and components. While not cheap like the rm Italy amps, they can take a bit more abuse and keep chuggin along. Another thing I always add is this, if you don't have a good antenna setup, spend the money on that first, get a good antenna, coax, and connectors. A good antenna setup is one of the main overlooked things and can make or break a system. Just my 2 pennies. Good luck and God Bless.
I have had very good luck and reports using a KL-503 connected to a Yeticom Optima. I primarily run in SSB mode, so this does not apply to AM> I run 8 watts PEP in SSB mode, variable switch on the KL-503 @ 4 and see about 200 watts output. I rarely have to turn the fan on (but do add a fan). I have always received good reports, no splatter and no TVI - even when using an A99. The KL-503 will draw about 25 amps on average meaning I could run both off of the same 36A power supply. Assuming you can keep SSB output @~8 watts I don't know why it wouldn't work. It is well known that any RM amp that is driven hard will fail.
I think your comment about the even/odd numbers is based on the fact that some RM amps use bipolar transistors, while others like the 503 use MOSFETs.
I know I am probably bucking the trend and most will suggest a true "2 pill" or more - and as already posted I do use a "4 pill" as well with another setup - but thought I would share my personal experience which I have run for about a year w/o issues.
In the end, it's dollars and sense (typo intended)![]()
