magnum s9 no tx need docs
DT307
New Member
Nov 21, 2019
6
5
3
53
magnum s9 9821r20
no tx output only slight rf getting to pa stage.
finals ,driver,predriver,pre-predriver all pulled and checked good tr56/43/44/45/46
wet finger on the balanced modulator pins (ic3) about 20w out or on the pre-pre driver 60w output
i think the issue is where the red wire comes from rear to a transistor on the front solder side next tied into the fm full power diode d506 as if i fit a diode i get 5w output on fm and am nothing on ssb (i can hear my self on a near by radio but not enough rf to drive the pa stage )
looking for a block diagram and a voltage chart so i can continue
(have contacted pallomar and no reply)
c122 also tested good and 8v feed to ic 3 (not the an612 i have on my diagrams but a standoff board with i guess an upgraded version )
yes thanks..nothing what i need i guess no 1 has them as Eric did mail me back and said all he has is on cb tricks ......find it odd the people that make them dont have a voltage chart or a block diagram. oh well old school bit by bit it has to be then
Well, does it have that "TP 6 TP7 TP8" stuff - how's that doing - do you get any voltages?
You know, AM Regulator stuff...
You can always post a pic of your board and if it's the older S9 series - I believe they use a Galaxy equivalent board layout - should be pretty simple for others to recognize and help you out...
Reactions: Robb
