Medium Wave
Exactly the same way a CBer transmits his signal. Only difference is the frequency and therefore the antenna length.
Well, there's the power involved, but they use heavier coax.
Why do i recieve better with a horizontal antenna over a vertical?
I'm not quite sure what you're asking. The AM Broadcast (AMBC) station is using a vertically-polarized antenna and the receiver is using a ferrite rod sitting horizontally in the radio case and you're wondering how a horizontally- polarized receiving antenna can receive a vertically-polarized signal...is what I think the question is.
The answer is that, for a local AMBC station, the RF field is so strong that just about ANYTHING would work as an antenna. True, there's about a 20dB "loss" because of cross-polarization, but your radio won't even notice that until you're several hundred miles away from the transmitting antenna.
What happens if you turn the receiving radio on its side so that the ferrite rod is aimed vertically? I'm guessing you won't notice much change.
From my home town (Las Vegas NV) I used to listen to KOMO radio (1000 KHz in Seattle) with a little shirt pocket radio. At that distance - ~1200 miles - I had to be careful to keep the radio sitting in the horizontal plane correctly. If the ferrite rod was vertical, it didn't matter.
If i turn the radios with the bar antenna facing vertical I'll loose reception quiet a bit ! All the stations i listen to are with in one hundred fifty miles or less.
While it is true MW stations transmit a vertically polarized signal, the towers ARE the antennas rather than a support for antennas, the issue with a ferrite rod antenna is not so much polarity as it is pattern. The response pattern of a ferrite rod antenna is like two balls that just touch. Imagine the rod running between the two balls. In the horizontal plane the response is good all around but next to nothing straight up and down. Turn that antenna on it's end and now you have good pickup straight up and down but next to nothing in a horizontal plane all around. That's the reason for the difference, not so much polarity.
