Meter Light
Big Kahuna
Sr. Member
Jul 31, 2008
1,161
2,151
273
Meter light in my Galaxy 959 burned out anyone know what to use for replacement size and volts or got a link to a replacement
I like to replace with the bright white kind if posible.
Well good luck with that. The big square Galaxy meter assemblies are built on a circuit board and none of it is easy to get to.
What you can do is string up a white LED and position it behind the meter assembly. The back of the meter assembly is opaque plastic and a new light will shine through the plastic and light the meter up just fine. A local friend did just that recently and it works well. You can hold the LED or bulb in place by strapping it to nearby wires with a rip tie or piece of black tape ect....
Good luck
