mic wirering
58xray 169
New Member
Nov 24, 2013
7
Chilliwack B.C Canada Eh
hey guys I got a old Realistic bullet head pre amp mic and want to wire it to my vintage navaho 490 >> Now this radio has no receive when mic plug is out and the bullet head has 4 wires , shield black red and white I have tried every thing I can to get this mic to work and I just cant get it ??? i did get it to Receive and key up but No mod ???? What is the trick
pin 1= shield
pin 2= not used
pin 3= transmit
pin4=audio /modulation
pin 5=recieve
this is for the radio . you,ll have to find out which wires match the pins
trial and error. if ya remember which one allowed audio then you have
2 pins figured out as remember pin 2 isnt used . this is all i could find
hopefully others will chime in
I'm not familiar with the Realistic microphone, but the mic looks very similar to a Turner +2. The Turner +2 has a switch in the base to select either relay or electronics switching. Just guessing that if that switch exists then you may need to select one mode or the other.
Is it possible that the radio uses an electic type of microphone? It is possible the blue wire carries a voltage to power the original mic element? I don't think a dynamic mic can be used in place of an electic mic, and that may be why you are not getting any modulation.
I also looked at the Turner +2 Connection Manual, and all it shows is a 4-pin wire arrangement that Hotrod described. Any 5-pin mic connections in the manual only use 4 of the 5 pins.
58XRay -
If it keys up and receives, then the mike is wired right, Have you checked the battery? If it's good, and there are no broken wires, then there is something wrong with the element or the amp board,
- 399
