ok so my current setup is as follows:
2.4mm wire, 2.4mm spacing, 31 turns around a form that is about 89m
the 3.5 foot mast, with about 6" hook up wire under the coil and a 52" stainless whip above the coil...
currently this setup will tune as low as 6Mhz on the dot
how big of a TOP mast and cap hat would I need to tune the existing setup into the 75/80m band?
My understanding of cap hats is limited
I think the existing coil is about 60uF @ 3.5Mhz
I do have room to add an addition coil near the first coil if I REALLY needed to
I use the #8 tap on my existing coil for 7.0Mhz if I calculated this correctly that should be about 40uF (which is about on target for a 40m, 9ft, center loaded whip...)
but I think I would need about 160-200uf to pull off 3.5Mhz with my current whip...
CAN a cap hat and say a 2-3 foot tall (TOP) mast with a 60uF (@ 3.5Mhz) coil achieve resonance?
