I'm assuming by tx/rx difference your reffering to the S meter readings involved,if so you probably won't see any difference at all,but that is far from the whole story,
Quality coax isn't just about the difference in signal,far too many people are hung up on coax attenuation and overlook its other qualities/shortcomings,
Far more important is the rfi noise picked up by poorly shielded coax that masks very low signals,not to mention plays a huge part in leaking rfi to other electrical equipment around you,then there is the issue of the stability of better quality coax when used in adverse weather conditions,generally speaking foam dielectric cables like rg8x are only good for indoor use,for reasons i've already mentioned,the cables generally break down pretty quickly when exposed to moisture or ulta violet light.Davis buryflex advantage is in its jacket,which is designed to be buried under the ground,which can help with rfi suppression,but going by the price of it I doubt very much if its built from high quality materials.
With your 60 feet or so run there will be precious little difference between any rf cables in s meter readings,its too short for losses to play a noticeable part,1 s point is around 6db gain or loss,very few coax cables will have that amount of loss in 60ft apart from the really cheap bargain bucket cables,but there could be a huge difference in noise pickup/rfi radiated which is nothing to do with the length of the cable.S meter accuracy is another issue which can give over emphasised losses or gains,as most are nowhere near the 1 s unit= 6db mark they should be,that includes most hf sets too.So going by s meter is about as accurate as tuning an antena with a swr meter,much better to use the two best test instruments nature provided,your eyes and your ears.Both are very sensitive,the ears will hear increased/decreased noise levels and your eyes will see that neighbour who's telly your ripping apart coming with a shotgun long before the f@cker gets a chance to pop you,
If you really want to see increased performance (not just s meter readings),buy a quality coax,like M17/75 RG214/u with the dual silver plated braid,which is excellent hard wearing coax,with superb shielding.The biggest problem you'll run into with this cable is soldering the plugs,the conductors are of such quality that they will pull the tip temperature down on any iron under 60w,i use an antex tcs 230 (temperature compensated) when doing rg214/u,tinning the braid can be difficult,but its well worth the effort over rg8x type cables,and at the prices you guys get it at it ain't a ballbuster.
Always solder the braid to the plug,not only does it give a better electrical connection,but it gives a better mechanical connection too,and stops the wind twisting the cable and the inevitable broken inner conductor that results.seal up with liquid electrical tape and/or self amalgamating tape and you have a connection that will last as long as the cable itself,which in the case of proper M17/75 RG214/u is 20 years,if a job's worth doing,its worth doing properly the first time.
If your feeling really flush booty,consider the andrew heliax range of ldf cables,or not as good/expensive times microwave lmr range.Both may be considered slightly overkill for 11m though.
