On 80m mobile operation the antenna is EVERYTHING and is not for the faint of heart. The Little Tarheel II is still a very short antenna for use on 80m unless you use a much longer whip. I have done a little bit of 80m mobile but just used an 80m Hamstick. Nevertheless I was able to work into the Midwest area, down into Florida and even a couple contacts into England all with just 100 watts. I would suggest that if you do go with the Little Tarheel II that you use as long a whip as you can on it.
I am going to put the 56" whip on it that is suppose to increase its ability, I have the ATAS 120 right now and really dont want anything much larger than that on my Explorer.
Maybe if I had a full size truck I would go with the bigger antennas. My ATAS has done really well and I have quite a few DX contacts in Europe with it.
