Been thinking of my 3 different Dosy Meters and the difference in the modulation readings on all 3. First off I bought a Dosy TC-4002-SW because I liked hooking 2 different antennas to it and a dummy load for my radio bench testing. After buying it my local guy that is into CB repair calibrated the watt meter to match the readings of his Bird meter which I don't seem to have a problem with. The part I question is the Modulation mode on the meter seems to be the most stingy reading ( more than a little ) of my 3 meters. The other 2 meters are a Dosy TFC-3001 & a Dosy TFC-3001-S which are close in Modulation reading but still different. The later being my favorite because I can check frequency reading on AM and SSB. The question being can the Modulation Meters be calibrated on all three meters to read the same reading. The problem being you don't feel like adjusting modulation on a radio if your not sure which meter is correct. And No I am not into radio repair but It would be nice to make a few simple checks & adjustments on my own personal equipment because my local guy is too busy with his regular job these days and it would be nice to turn down the dead key & turn up the modulation a little. Anything after that I'd leave it to the Pros because my investment for a hobby is over. Thanks in advance. Mike
