Motor maul's
bigred222
Key Up City Radio
Aug 28, 2006
1,155
53
58
36
Stamford, CT
www.cbjunk.com
if you look on a motor maul and ive even seen video's where there are so239 connectors on the actual device, now I always thought that motor mauls were for charging batteries. Why do you need to connect your antenna/amplifier's rf connectors up to this device? Am i missing something here?
~Big Red~
RF switching..
when keyed the relays in the Motor Maul put your 12 volt batteries in series making 24 volts. then it regulates down to the set voltage.
when you un-key the relays disconnect and allow your alternator to charge the batteries at 12-13 volts.
