Most MURS use seems to so far be with the short range handhelds. But what the hey...WE like our big radios and extra power....so if you can swing the gear, why not use a full power mobile both mobile and as a base. All the ham 2 meters mobiles mod out to cover MURS. So there ya go, a 50 watt radio. I have a mobile for 2 meters/MURS/Business Bands in the truck and even more capability at the house with a rig that does 100 watts on VHF.
For a most used itinerant frequency, 151.625 is still the most used. Again the ham 2 meter rigs will shine here.
The only problem remaining for ham/dual use, is having an antenna system that will cover both ranges with a good SWR. A tuned-for-2 meter antenna will be seriously out of tune for even the 151mhz channels. Either need some sort of screwdriver arrangement, a really good VHF antenna tuner, or best would probably be two separate antennas.
Good luck and have fun with radios!!That is an order! Carry on.![]()
Try the MFJ-1728B, it can be used for 2 meters and MURS at the same time with good SWR.
What is the 151.625 freq?
As I understand it there is a 2 WATT LIMIT on a MURS transmission but there is no longer a limit on ERP or antenna gain. Blasting hi wattage on these freqs will only cause trouble for induviduals and lax conduct will only hurt MURS potential and future.
