Need a couple HR2510/Lincoln Parts
CSA1863
82
64
North Alabama
I'm in need of a couple of parts for a HR2510 radio I'm attempting to restore and thought I'd ask here.
These are the part numbers/description from the HR2510 Service Manual
Y301 - BYYY0548001 Ceramic Resonator YY-548 CSA2.000MK (Blue 2 Pin Ceramic Resonator 2.000 Mhz on the CPU/PLL board)
VR601 - BRVY0672001 RV-672 5KB Variable Resistor (SWR Calibrate Potentiometer)
No Part Number - VFO/Channel Selector Knob
If you have any of these and are willing to part with them let me know.
Thanks!
I might have what you need, let me check and see. Brandon sent me a 2510 parts rig and I have taken all I need from it.
Thanks!
Yes, I have all, not sure if they are good or not, but if you pay the shipping you can have them.
I bought an entire unit for $150 off ebay so I would have spare parts for my minty Lincoln. Granted I got a HR2510 but that is what you do. I will take it apart and recap it and then store it away. I do not want old capacitors leaking on the working unit and ruining it in storage.
So each old radio you own that no has unobtanium parts it is good to have 1-2 spare parts donors.
I had 3 non working 2510's. One of which was in a fire and the front bezel was melted into a big plastic glob. So that one is my "donor" and I have already pulled all the parts that are still usable, bagged them up and put away till needed. Of the remaining two one is repaired/restored and working like new. The second is on it's way to being a working unit thanks to Cable Guy's generosity.
If I had a 2510 that was going to be used as a donor I would make sure to remove the brown glue from wherever it may be, recap the CPU and display board and just pull the old caps off the main board and not worry about installing new. Less time and dollars sitting on a shelf. Different story if you want it as a working radio
Reactions: Onelasttime
You can never find a Lincoln for sale or I would have one as a spare. Well not entirely true a few years back I saw a chip switched minty one out of Europe on Ebay for $1200 or $1500 plus shipping!
As much as I like my Lincoln $1200 or $1500 is too much. I could purchase a real HF rig for that price!
I am sentimental and nostalgic but only to a point. I like utility more than anything and sadly a $158 Aris II or $202 Radioddity RT-60 can do more than my old Lincoln can.
