Need Grant LT (or similar) Channel Selector
hi superlid.
do you mind giving a few details about what happened to the old switch?
im asking because there is a chance it's repairable, or not actually the culprit.
I believe that some Cobra 25's and 29's use the same switch. Also I believe the 2950 as well. I have to check the other possible switch marking that works. I don't have one or a parts donor.
Can the outer plastic be swapped with one from a different switch while keeping the green switch sections the same? I've never taken one apart so I don't know.
  • @ Spanish:
    Where do i upload schematics
  • @ Catalyst 122:
    Who do I contact for a name change. I put in for it over a year ago and it says still under review.
