New RM amp approved by FCC
Yupp and a rediculous price as now they can cash in on the type accepted or approved market ;)
I'll be the first curmudgeon to get riled. Couldn't they have come up with a better look to the front panel? It looks as if it was designed for the good buddy market and by that I mean the GOOD BUDDY market! LOL :biggrin:
on the bright side, it might mean less spectrum pollution emanating from 11m, surely that can't be bad and is a relatively cheap route to some hams getting a bit of power going on 10/12m without expensive hf sets and 100w drive amps. must be better than the dirty cb amps used currently.
Reactions: 3 people
§97.317 Standards for certification of external RF power amplifiers.​
(a) To receive a grant of certification, the amplifier must:​
(1) Satisfy the spurious emission standards of §97.307 (d) or (e) of this part, as applicable, when the amplifier is operated at the lesser of 1.5 kW PEP​
or its full output power and when the amplifier is placed in the “standby” or “off” positions while connected to the transmitter.​
(2) Not be capable of amplifying the input RF power (driving signal) by more than 15 dB gain. Gain is defined as the ratio of the input RF power to the​
output RF power of the amplifier where both power measurements are expressed in peak envelope power or mean power.​
(3) Exhibit no amplification (0 dB gain) between 26 MHz and 28 MHz.​
(b) Certification shall be denied when:​
(1) The Commission determines the amplifier can be used in services other than the Amateur Radio Service, or​
(2) The amplifier can be easily modified to operate on frequencies between 26 MHz and 28 MHz.​
Looks like they dropped the 50 watt input rule. But can not operate on 11 meter without some major mod.
Rich
