New Set UP HELP!
speterson1011
Oct 30, 2009
4
So i'm about to upgrade to a Wilson 1000 roof mount from a lil wil. I'm running a 110watt 1pill amp on a cobra 19 ultra III tuned at 10watts. Will this set up work decent? All criticism welcome. Thanks in advanced everyone
The antenna is a huge upgrade, however 10 watts carrier into a single transistor (depending on which one it is) does not leave much breathing room, if that is Modulated power then you should do well.
Later if/when able your next upgrade should be a little better radio, a nice old 148GTL (Side Mic) or even one of the more feature rich AM only chassis would be another very worthwhile upgrade :thumbup:
The radio is now doing 10 watts. Which is fine, unless you are considering using power. Do you mean 10 watts PEP - or dead key watts? If it is 10 watts PEP - that would be just fine.
I for one don't use a linear, I just use an export radio with the Wilson 1000. Upgrading to different radios is a process met by opportunities and choices. I had no idea that I was to find a Galaxy 99V until the opportunity presented itself. An older Cobra 148GTL would also be an excellent choice. But going to a more powerful radio will mean that you may have outgrown your 1 pill amp.
I am sure that you will see a large difference between those two antennas. I'm not saying the Lil Wil is a bad antenna - as I never owned one. I replaced a K-40 with the Wilson 1000. There was a VAST difference between them. BTW- a K-40 isn't a bad antenna either. But the Wilson 1000 is outstanding.
