So, I have three applications. Base, car/truck, and boat. None of my purchases are here yet and the boat is having the upper deck replaced, so I am learning about antennas and CB radio, mostly by watching YouTube videos on these subjects. I bought a Wilson little will for the car, and a Dipole kit for the tree. I have been asking Google AI a lot of questions based on what I have learned. Today I asked about Centerpoise Antennas and how to build a boat antenna using these principles. You guys have more experience than I do. I have this antenna designed with 2 u shaped ground radials, sloped down at 22.5° with a removable whip for towing and bridges, and stowed with the centerpoise parallel with the keel. The base will telescope 4-8 feet to clear the flybridge and angle to rotate 90-120° Everything is a compromise on a boat.
What do you think?
The end result is listed here below.
AI Mode Conversation
You said: now that we have the antenna designed with u shaped counterpoise at 22.5° down, what is the proper name for it?
The proper name for this configuration is a
drooping ground plane antenna (also commonly called a
1/4-wave ground plane antenna with drooping radials or an
inverted-V ground plane).
While your specific physical build uses a continuous wire bent into an open-ended "U" shape at the base rather than two separate wires, electrically and functionally it operates as a
two-radial drooping ground plane.
Here is how the specific features of your design break down in standard radio terminology:
- 1/4-Wave Ground Plane: Refers to the vertical radiating element working against an elevated artificial ground (your counterpoise), rather than being mounted directly to the earth.
- Drooping Radials: Angling the counterpoise wires downward (at your 22.5° angle) raises the antenna's feedpoint impedance from roughly 35 ohms closer to a standard 50-ohm match for your coax, without needing an external matching network.
- Two-Radial / Bi-Directional Counterpoise: Because it uses two opposing legs (formed by the U-shape) instead of three or four, it creates a slight oval or figure-eight bias in the radiation pattern rather than a pure circle, though it remains broadly omnidirectional.
If you are logging it, describing it to other operators, or looking up modeling data, calling it a
quarter-wave ground plane with 22.5° drooping radials will immediately tell any radio enthusiast exactly how it is built and how it performs.
Would you like help with:
- Tuning procedures (adjusting wire lengths for the lowest SWR on 27 MHz)
- Coax routing and choking (preventing common-mode RF on the feedline)
- Expected radiation angles for local vs. skip (DX) contacts?
What are the Expected radiation angles for local vs. skip (DX) contacts?
For your 1/4-wave drooping ground plane antenna on 11 meters (27 MHz), local contacts rely on low radiation angles near the horizon (0° to 10°), while skip (DX) contacts rely on takeoff angles between roughly 5° and 25°, depending on how far away the receiving station is.
Because your counterpoise radials droop at 22.5°, your antenna naturally concentrates its maximum signal lobe right around 15° to 20° above the horizon (depending on mounting height), making it well-suited for both local ground-wave and medium-to-long-range skip.
1. Local Contacts (Ground-Wave / Line-of-Sight)
- Target Angle: 0° to 10° (hugging the earth's surface).
- How It Works: Local contacts (typically within 10 to 40 miles) do not bounce off the atmosphere. They travel via direct line-of-sight and ground-wave propagation.
- Your Antenna's Performance: Vertical antennas naturally push strong energy right along the horizon. Getting your feedpoint 30+ feet high clears local terrain, trees, and roofs, maximizing this low-angle horizon energy for local talking.
2. Skip / DX Contacts (Skywave)
- Target Angle: 5° to 25° (aimed up toward the ionosphere's F2 or E layers).
- How It Works: To talk hundreds or thousands of miles, your signal must shoot upward at a shallow angle, refract off the ionized upper atmosphere, and bounce back down to earth.
- 15° to 25° (Medium Skip): Typically lands 600 to 1,200 miles away on a single hop (e.g., reaching the Midwest, Florida, or New England from Virginia). Your 22.5° drooping ground plane peaks right in this sweet spot.
- 5° to 12° (Long-Haul DX): Grazing angles just above the horizon stretch a single hop out to 1,500 to 2,500+ miles (cross-country or international).
- Above 35° to 40° (Too High): At 27 MHz, signals aimed too steeply upward usually punch straight through the ionosphere into space rather than bouncing back down.
Quick Summary by Contact Type
| Contact Type | Distance | Ideal Takeoff Angle | How Your Design Performs |
| Local | 0–40 miles | 0° – 10° | Strong horizon punch (improves with height) |
| Regional / Medium Skip | 600–1,200 miles | 15° – 25° | Peak lobe zone for 22.5° drooping radials |
| Long-Distance DX | 1,500–2,500+ miles | 5° – 12° | Good low-angle lobe, especially mounted 1+ wavelength (~36 ft) high |
(Note: Raising the feedpoint closer to 36 feet—one full wavelength above ground—helps pull your main radiation lobe down toward that lower 10°–15° range, boosting both local range and long-distance DX at the same time.)
Would you like to look at:
- How mounting height (e.g., 20 ft vs. 36 ft) shifts the takeoff angle on 11 meters
- How to build a simple coaxial choke to keep feedline radiation from distorting this pattern
- Step-by-step SWR tuning once you get the antenna mounted?
