New to the forum, have a question about my Tram D42
(_8*(l)Homer
New Member
Sep 8, 2014
2
So I have a Tram D42, which worked very well when I last used it maybe 12 years ago. Yesterday when I turned it on, there was a loud POP, and the smell of burnt electronics. The transceiver still seems to function properly, I can transmit and I can see on the meeter when I receive, but there is no audio.
I think whatever controls the audio has blown, the speaker works when hooked up to another source. The headphone port only provides a loud hum sounds regardless of the state of RX.
How can I trace the fault? I opened the box and I can smell various burnt electronics, but nothing is visibly burnt.
Thanks, and I look forward to talking with the community here :)
Joe
I suspect a bad electrolytic capacitor in the audio amp is the culprit. They have a tendency to short out if allowed to sit for a time. If I where you I repalce every one in the radio before you go any farther. You have needle movement but most likely it is a dead carrier with no audio.
I was transmitting from handheld in the same room, so the carrier had audio. I will replace the caps as you stated, there aren't too many on it, which is good.
